Changing color stripes on hull
Pat T
I have a 1995 and it has the 2 color stripes along the hull as most do. They are grey and tourquoise. The grey is ok but not the tourquoise. I want to change to the current colors of grey and blue. Where can I get the tape to stripe the boat? Anyone have any experience or tips for me? I heard a hair dryer can be used to remove the old striping? What about applying over the old stripes? Thanks.
A
artfuldodger
tape
I just picked up stripes from Tidewater marina in Havre de Grace, MD it was $1.10 per ft. I got 80 feet. the tape comes with paper on both sides on side is sticky and the other side is to keep the distance proper when applying.
Catalina 320 Dana Point
I used 3M tape from the attached website,
think it was $40 for 150' roll. Do not try to tape over the old ones, I use plastic putty knife and heat gun, just get it warm enough to loosen adhesive. Also some car body supply stores have a device called an "eraser wheel" basically a gum rubber disc for a drill that is supposed to be very effective, I've not used one.
Jun 9, 2004
615
Catalina 385 Marquette. Mi
Stripes
Catalina sells the stripes. I have a spare roll of blue and green for my 97 270. The two colors are on one piece of backing tape for even install. Doug
