I tried to change the alternator belt (V-belt) and water pump belt today on my Yanmar 3YM20. Looked pretty easy, loosen the set bolt and "slide" the alternator towards the engine to give enough space/slack to get the belt off. Problem is that I loosened up the set bolt but the alternator wouldn't budge. Tried using a wooden dowel to provide leverage but to no avail. I sprayed Corrosion Block on the groove/set bolt that allows you to adjust tension on the alternator belt because it was rusted and will try again in the morning. Any other suggestions. Is there something else that I need to loosen up. Thanks in advance.
Mike
Mike
