Your sail plan is designed around a large roach main
to power the boat. The headsail is used for balance and to help pointing ability with minimum effort from it required to propel the boat. These boats are fairly light by design and have good small air performance. It seems to me the installation modifications required for a Genoa and the ensuing problems with sail shape are not worth the performance gained in a narrow band of wind speed. Your boat as is can probably be propelled to its theorical hull speed in around 15 knots of wind speed. Above that you are wasting the additional power of a 150% Genoa and adding a lot of stress to the rig. The hull shape does not take kindly to a high degree of heel as far as boat speed is concerened. At higher wind speeds you will need to reef or partially roll that Genoa up loosing sail shape. Installing the sail itself may require for you to reposition or install additional tracks for fairlead blocks. A large Genoa would need to go outside the shrouds so your new tracks may need to go on the walking decks aft of amidship. Do you have cockpit winches at a favorable angle? I'm sure it can be done, as I'm sure someone may have done it but I question if the cost, labor and compromises are justified by the gain in performance. I even considered a 135% for our h320 and gave it up. Now the addition of an asymetrical spinaker would complement your present rigging quite nicely.
