Don't grind you gelcoat away with compound!
You should only use compounidng when the gelcoat is very rough (feel with finger nail)or the outer layer of the gelcoat has fading of the pigmnet (red beomes orange etc). The smart thing to do is to SELECTIVELY DISSOLVE AWAY the chalk, using Island girl Cleansers. This does not thin out the gelcoat (very important on stripes) or rub through on edges. Use IG Pink chalky non-skid (because it can be rinsed off). On smooth gelcoat, the cleanser conditioners (CLEAR FOR NEUTRAL COLORS, SEA GLOW FOR WHITE, BLUE, RED & OTHER BRIGHT COLORS)will not only remove chalk on surface but also deep down (again by chemically dissolving and "drawing up"). THis is the only way that true depth can be brought back to black or dark blue.THe surface should then be sealed to make it watertight and shiny (the shine comes from thickness of sealant. Use spray on SILKENSEAL sandwiched around a layer of collinite or similar stiff paste wax. Or use our sealant/wax combo (temporarily out). I have also seen good results with POLYGLOW over SEA GLOW, but have not tried on white gelcoat.OK- I know this sounds like an advert but if you know of any other cleaner that similarly dissolves out the chalk without wearing away the boat - use it!(my Lee Iacocca line).Otherwise thanks for the mention anyway!Jim WThe only time compounding (with or without wet-sanding) is necesay
