A non-skid reply to a new FAQ
Q: I used Pink and non-skid sealer on my decks. What should I use to cleanthe decks when they get really dirty? I dont want to remove the sealer. Willboat soap or dilluted Pink remove the sealer I put on? A: When first done, a good high pressure hose and a soft brush is all that is required- bird droppings just "float" off. If the the stains are "oily" (lots of air pollution) then just use tiny amount of pink in a bowl of wateror (no direct experience but more expensive) DILUTED boat soap. If you have bad spills (cetol etc) use the pink undiluted with a stiff brush this will also remove top layer of sealant so that you will have to touch up. DO NOT use oxalic based harsh cleaners, Ajax etc!After a few month in the hot sun, and lots of foot traffic, you will notice that the water beading is not so dramatatic and that the sealant surface has dulled a bit and is not so easy to clean. The sealant is taking the weathering rather than the deck itself. At this point, just use some pink undiluted to strip the bad surface, exposing good sealant underneath and touch up the surface with a thin coat of sealant.You can keep doing this indefinitely and the sealant layer will build up to a very tough layer. I have areas that have been treated this way for 2years!The main thing is that the deck is completely cleaned and prepared before being sealed and DO NOT put the sealant on too thick at one time (will attract dirt/footmarks if not set up properly). Pat/brush out areas that in which sealant can "pool" and rinse with water when dried at least to the "tacky" stage to rinse away uncured components and suspending agent. Rinsing between coats (if appying more than one coat in a day) also prevents trapping of uncured (sticky) components.ThanksJim W>
