Just seeing the additional bolts through the hull increased my confidence level in the plates by about 200%. However, I would have gone with longer plates just to increase the ability to install another two bolts below the existing two your host has. If in doubt, overcompensate. The inside attachment to the hull is not too encouraging. Actually, bloody cheap.
The length of the two plates is limited by the curvature of the hull i.e. how long can they be with only the one bend under the rub rail (as we can see in the pictures) before they are just floating in air.
Given another two bolts below, the area of hull subject to shear would be increased and the shear stress reduced by possibly as much as 50%.
I know this seems like overkill but when I look at mine and I look at yours, I don't see how they've lasted as long as they have. The H-410's and up I have seen at boat shows ........... the outer shrouds are like solid I-beams. Rock solid so I can imagine the stress. Mine are scary enough.
Question for you. I see your neighbour's chain plates are 12 mm thick. What thickness are your original plates ?
The only other consideration I can see "do you plan to repeat the two topmost bolts which pass through the toe rail at the deck level ? Couple of head scratchers there.
