Hello everyone,
In the extensive refit of Lyra (v2941), I am contemplating replacing the
triangular-shaped eyes that fasten the shrouds to the chainplate. As mine are
showing some wear in the apex of the triangle(on the inside), I am not too
keen on sailing extensively with such a setup. Has anyone tried replacing
those? Is it possible to find the originals or could it work to replace them with
round eye bolts (Wichard makes some that would fit with a safe working load
of 6,600 lbs). The backstay is a little more complex, as I would need more
clearance than a small round eye bolt could give.
Any suggestions?
Has anyone cruising extensively reported any trouble with the original Vega
chainplate arrangement? Or the backstay bases?
Thanks a bunch for any help,
Cedric
Any suggestions?
Cedric
