376 Anchor Rode
Bob,The anchor chain on a 376 builds up in the locker and jams in the navel pipe. I modified my boat to feed the chain into the centre of the locker. This involved sawing off the pipe just below the windlass and making a joint to a new piece of 2 ½" PVC pipe and through the vertical bulkhead at approx 45°and then into the centre of the top of the chain locker. This meant having the new pipe between the berth cushions, but this is okay because the berth is over 7' long. This largely solved the problem but I still only use 100' chain before going on to rope. Any more chain would still pile too high in the locker and fail to topple. This will then jam the pipe as before.Please look into the archives as it is an unresolved problem on the 376.Regards,
