Is it a bad idea to seal the interior/exterior chain plate areas with the permanent sealant caulk 3M 5200? Does anyone have experience with this stuff?
I purchased this for sealing the engine mount, rudder hinges and any of the thru hole mounts above and below waterline.
Just curious if it will work well on port/starboard chain plates or if it will be a huge problem further down the road if/when I need to reseal them again.
Thanks,
Joe
Thanks,
Joe
