I used a hawsepipe, and it fit very nicely. But I put it centerline,
which weakens the forepeak, which could be a mistake. You might consider
putting it off center. I also put a hinged door onto the forepeak locker
(I think it was originally suppose to be a small sail locker). This
converts into a very nice chain locker, as it drains directly into the
bilge. I store the "normal" anchor hanging off the pullpit, as its a
danforth, and you can get the stainless steel holders and put them on
easily. I have wrapped the pullpit with 1 inch thick clear water piping
to act as chaffing gear...... it works well. But I would take the CQR
out of the stern locker if real holding power is needed. As to
reversing, until you get way on, its usually the wind that determines
which way you will go, my Vega has a tendency to put her stern into the
wind, as more sail area is forward of the pivot point........ Hope this
helps.....
Hal
Harold J. Kearsley
882 Bull Run Road
Northfield VT 05663
(802) 485 - 4300________________________________________________________________
Sign Up for Juno Platinum Internet Access Today
Only $9.95 per month!
Visit
www.juno.com
