1991 P42 all chain rode
I carry 350 feet of 5/16 inch chain rode. I also have a 1991 P42, which originally came with the Maxwell 700 windlass. I found the windlass to be underpowered for pulling in that much chain in a 75 foot deep anchorage under bad weather conditions. It would often cause the windlass breaker to switch off, causing unpleasant situations.. So I upgraded to the Maxwell 1200. The bolt pattern has changed a bit where the windlass and cathead holder bolt together through the anchor locker, but a machine shop easily machined my old cathead holder to adapt to the 1200 model. It works great, and has plenty of power.Regardless of what chain type you use, Maxwell will provide the proper size cathead for your chain at no additional charge. Just contact them before installing the new cathead.Good luck.
