John
Over the Memorial Day weekend we were on a five-day outing. On day three I was looking over the engine and became curious about the way the engine waterheater lines (two) were secured to the alternator mount. They were secured with an electrical tie that pulled the lines tight up against the alternator mount. I pulled the hot water lines away to check them and noticed one had nearly chaffed clear through. The engine only had 40 hours on it. I cut the eletrical tie off and duct taped the chaffed line in an attempt to prevent failure. I padded the lines and resecured them to the alternator mount, but this time with padding between the lines and the mount. We made it back home (about 40 miles) without incident. If your hot water heater lines are secured in similar matter, you may want to check them closely. I believe we caught ours in the nick of time. We will doing a more permanent repair later this week.
