Not sure about cetol. I've coated the teak on my boat with epoxy (2-3 coats) and then over coated that with 2-3 coats of varnish. Turned out quite nice and is holding up exceptionally well. If you do use this process remember to use "clear" hardener. Good luck.I am currently refinishing a teak bow pulpit that is made up of many boards laminated together it is showing some gaps between the boards. Can I sand entire piece down fill gaps with epoxy sand flat and finish with cetol??
Pafb ..................... you took my old favorite away.Not sure about cetol. I've coated the teak on my boat with epoxy (2-3 coats) and then over coated that with 2-3 coats of varnish. Turned out quite nice and is holding up exceptionally well. If you do use this process remember to use "clear" hardener. Good luck.
Yes, I regularly repair cracks in my teak toe-rail using West G/flex colored with teak dust, sand, and refinish with Cetol.I am currently refinishing a teak bow pulpit that is made up of many boards laminated together it is showing some gaps between the boards. Can I sand entire piece down fill gaps with epoxy sand flat and finish with cetol??
