Cetol or Varnish?
150
Hunter 23.5 Cypremort Point, LA
I am trying to get a jump on my wood this winter and want input on the pros and cons of each product Cetol vs. Varnish. Durability, ease of application etc. Everyone pipe in please. Thanks Jonathan Costello Heeling Powers
Steve O.
Cetol
I have tried all and have settled on Cetol. Easiest prep, easiest application, and best durability. Some used to compalin about the color but more options are available now.
Jun 3, 2004
123
- - Deale, Md
Cetol
I bet your question gets asked a lot. Everyone has their own answer. Here's mine: Varnish done right looks much better than Cetol. Most varnishes will require very careful prep and about 7 coats. It won't last as long as Cetol before you either have to strip it or carefully feather on another coat or two if you haven't waited too long. Cetol, on the other hand, is much easier to use, lasts longer, is much easier to maintain, but doesn't look as good as varnish. Having said that, I have been using Cetol for the past 10 years and will continue to use it forever. Cetol is the best product for people who like to sail a lot and want their boats to look pretty good. Varnish is for people who are going to have less time to sail, but will have better looking teak on their boats. Take your pick.
May 24, 2004
150
Well put and simply put Warren
Thanks. My researching shows the consensus is for Cetol with the tradeoff that it doesn't look quite as good as varnish but the pros of Cetol outweigh the cons. Thanks for the input.
