Bob I don't have specs any more but I can probably walk you through taking dimensions to make or have one made. The original was solid fiberglass with a lead weight molded in. In fact it was exactly the same section as the 245 kick up rudder with a modification in length and profile. You could easily cut one from steel plate if you are willing to sacrifice aesthetics and a little bit of performance. PM me if you are still working on this.
