John Haley
Greetings,I'm looking at a '79 Irwin Citation. The owner says fixed keel, the survey they supplied says "fixed, centerboard". The seller (owner for only two years)says they never noticed if it had a centerboard, and are a tad embarrassed. I found the brochure which says the draft of the fixed is 5'4" and the centerboard models are 4'. Owner says draft is 4'. Sooo.I believe it is a centerboard. I did see another boat online where the owner removed centerboard, added weight and glassed over it. My questions for the group:1) Where topsides is the mechanism for lowering the centerboard so I can point it out to the owner (maybe he is right about not having a CB and is wrong on the draft).2) I'm inclined to pass if it is a CB or if the CB has been removed. I'd be sailing on Lake Ontario and if the designer hung a big plank off of the bottom of the boat he probably had a good reason for it.Your thoughts?JohnPS I am shopping long distance. I will have an out of the water survey done before purchase to resolve all mysteries but it would be great to spot this ahead of time.
