YES
I've had a few small cracks just 3" or so foward of the trunk, about 3 to 4" long. Seems the annual bottom paint covers up and doesn't appear, but you can tell if you look just right. I believe they to be surface cracks and not in the fiberglass structure, even so it would be into the tank area. I think there is a lot of stress in this area due to the compression post and the 6 foot board that has a tremendous amount of forces reacting. A downwind run in swells can really put back and forth pressures on the board, enough that once I believe I observed movement movement (1/8") between the compression post bottom and the surrounding finshed trunk. No chips in the well, but you bet I'll be looking closer this spring! good luck
