centerboard repair
2
- - belleville
hello everyone. i hope the sailing is smooth. unfortunately, the front edge of the centerboard on our hunter 170 is starting to split. please offer any advice on removing the cb, repairing the split, and replacing the cb back to its proper position.
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
Remove screw
I had mine out last year. Remove the one screw in the bottom of the board, and then lift out the top. I think it's about 70lbs. JerryA
Mar 8, 2005
193
Hunter 170 Ventura, California
SPLITTING ?
What is causing it to split ? Is it under warranty ? If not, is it an easy fix ?
David
CB repair
Hopefully, your CB splitting is covered by warranty, try calling Hunter. They were very helpful when my CB started swelling. I wonder if yours has the same problem. I guess a certain number of CB's were manufactured with a material which swelled when wet so any opening in the outer cover led to swells and cracks in the CB (mine had a tiny crack near the screw in the bottom of the board). Hunter mailed out a new board to me ASAP (covered by warranty) and replacing it was not too bad, just a little awkward becuase of needing to lift that weight (~70 lbs) out of the CB trunk.
