Centerboard questions for Dave
May 11, 2016
11
Hunter 240 PatokaLake
On the yoke for the centerboard do you use the same roller and pivot pin holes on a 1999 240 as on the 26/260 shown in the post on 9/12/08 & 1/17/16? Should the bottom bunk boards touch each other, or have a gap between them? Should the centerboard rest on the bottom bunk boards with slack in the up haul line, or should the line be tight while trailering? Lastly, the bottom corner of the leading edge of the Centerboard has a 3" grind mark into the fiberglass. Can this just be sealed with epoxy, fiberglass, and paint or does that need to be built out to a 90 degree angle? Thank You, Don
