I have a 72 19' O'day. Water is leaking from the seal on one side of the pivot bolt. I have purhchased a new bolt, washers and rubber seal. Looks pretty straight forward once I am able to keep my center board stationary. Curious to know if anyone has done and if you put some type of grease on the bolt or liquid sealant around the rubber washers. Also, to make sure I do not overtighten my assumption is one should just tighten until you can see the rubber seal is beginning to compress.
Any help would be appreciated.
Thanks
Pdavies
Thanks
Pdavies
