So I dove under my boat to see why my pendant was not moving, and I found out that the pendent is no longer attached to the board. The board on my Oday 23 is fully down, and the "loop" that was glassed to the trailing edge of the board (where the pendent attached to) is gone. Has anyone ever had to fix this before? Other than trying to recreate that loop, I had two thoughts: fasten a piece of stainless to the board (like maybe a small pintle), and affix the pendant to that. Or, drill a hole through the board near the trailing edge itself, fill with epoxy, redrill, and directly affix the pendent through that. Ideas?
