Or Inside Cabin?
Earlier OD25 models (not sure which year they stopped), had a small winch within the cabin attached to a post that the drop table rested on. I have a 76 and Gary is correct, below the bridge deck within the cockpit. The CB weighs only about 30lbs, and is a directional CB only, no ballast. The ballast is within the stub keel. Check out the condition of the nylon line. The attachment clip on the CB can be a real nuisance to replace. Good luck.Don
