Centerboard models - Sheave replacement
NYSail
Jan 6, 2006
3,184
Beneteau 423 Mt. Sinai, NY
Hello all, I finally disassembled the cable run for my centerboard on my 1986 P36-2. I had a slight leak at the base plate that the p/o kept putting 5200 ontop of.......The two upper sheaves and housings appear to be fine with no pitting in the ss and the sheave spins easily. However, the base sheave housing (where my slow leak was) is extremely pitted from electrolysis. Also, the bronze sheave is froze to the side of the ss housing and obvously not spinning. The pitting is on the ss housing on both sides of the base plate as well as on the inside walls where the sheave is. Attached are basic dimensions. I am bringing this piece to a welding shop this week to have a new one made and was wondering if anybody else was in the market for a new base sheave housing?? Maybe get an economy of scale pricing..... Was also wondering if I sould have a ss sheave put inside rather than the bronze? The ss ones I have seen on the market have a bronze bushing inside the pin. Greg 1986 P36-2 #101 Four the Soul
A
Ariel
Centerboard Sheave
Greg, Thanks for the picture and description. Have you found a supplier for the bronze pipe and union? Dave
NYSail
Jan 6, 2006
3,184
Pipe
The pipe is in actually good condition, however yes I have found a place. I am thinking about options to the unions....maybe rubber hose clamped on so as to keep the metals apart and make it easy to service.
NYSail
Jan 6, 2006
3,184
Rebuild
My base Sheave housing is currently being replaced with a completely new one made by a welder that has the identical boat!! Got a new 3" bronze sheave also....she looks sweet! I bought new unions for the entire pendant run from McMaster Carr, however switched to 316 ss rather than bronze.....The bronze pipe originally on the pendant run is in good shape so I will reuse it. In the future, I may switch this all to 316 ss. I will post pictures when I have this finished Greg
