Dean Eiland
I have a question about the centerboard on my H26 and I apologize if this has been addressed before. During my last cruse the line that attaches to the centerboard, which pulls the board up, broke. Actually the factory turning block on the deck blew apart (we maybe should talk about this) and left the line at a 90-degree turn against the fiberglass, which quickly sliced it in to. This all happened at 3:00 am as a front with 30 kt. winds was blowing through which left the center board grounded while we were on anchor. We quickly ran a line under the boat and pulled the centerboard up by hand, however, the board experienced some lateral force on bottom as the boat swung on the anchor.I have two questions, first how do you change the centerboard raising line, and can you do this on the trailer? And second, how, or is it possible to check how much side to side play there is in the centerboard? I am afraid sitting on bottom in the storm may have damaged the pivot bearings in the centerboard.Thanks for the help,Dean"Chateau de Vent"
