centerboard cable
6
- - bayville
I need to replace the centerboard cable. it is a wire to rope splice. i need to know how long the wire and rope should be along with the sizes for each. maybe someone knows where i can buy a preassembled set. thank-you mike b.
james
Try Rudy
I had the same arrangement and purchased a replacement from Rudy at D&R Marine. It is all line with no wire and has worked fine. http://www.drmarine.com/
Jul 1, 2004
6
- - bayville
thanks james, can you tell me how it is attached to the centerboard without a knot keeping the rope from jamming into the centerboard trunk.
K
Keith
Can do in all wire
I also have a 23 and previously replaced the centerboard and pendant. I got all of the parts from Rudy at D&R. My previous pendant was all wire. Rudy made up a new one of all wire (soft braid SS) including a swaged narrow deep throat shackle that was pinned through the centerboard. Works great! Soft wire is more durable than line and winds neatly on the pendant crank.
Jun 4, 2004
14
- - Lake City
You might want to try
using plain dacron line. On my Oday 25 I just drilled a larger hole in the CB and installed a 1/4 in. line and it worked fine. The knot at the CB should be close tied and the knot should be small. I think I used a square knot. The CB for the Oday 25 does not weigh much, so the 1/4 in. line is just fine.
Jack Spencer
C/B pendant
The attachment has rusted off my centerboard and I need to know what it looked so I can have a new one made up. My boat is a "79 23 and I want to keep the rope & wire pendant that was orginal. If anyone has a discription or a photo, please post it.
