carpet
carpet is attached to plywood. Tak all the hardware off and remove the plywood with carpet on it. DON'T through it away, yet. Use the old moldy stinking carpet covered wood as a templet to trace out new headliner on new wood. Plywood if you want to glue carpet on it again (I wouldn't). I traced mine on a nice piece of laun, got fancy and routed grooves every 1-1/2" and coated both sides and edges with epoxy. Install back in the boat. Keep the wood light (in color) and the cabin will be brighter. Easy to clean, looks great, will out last any carpet. Won't melt if the lantern is hung too high. Won't mold, mildew, and if it gets wet will dry fast, and not smell. Oh and lighter. If you need the insulation factor of the carpet, add 1/4" foam between the wood and the cabin top. Still lighter, more insulation, and added floatation.
