Cedar Lockers ?
Nov 12, 2014
90
Jeanneau 42 Northport
While brainstorming the other day I came up with the idea of lining the hull of my lockers with cedar to help keep them dry and smelling nice. Currently the lockers hull side is lined with carpet and or vinyl, they are a little musty :doh:. I would rip this out an neatly cut and liquid nail ceder in its place. What do you captains think? Brilliant or just plain silly?
Jun 11, 2011
1,243
Hunter 41 Lewes
I'm not sure about the adhesive you have chosen but you can't beat cedar in a closet!
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Cedar strips would be better than carpet, putting them inside the locker would be like planking. Cedar strip canoe from the inside. The cedar would certainly help keep out some bugs.
Like uncledom, I would question your choice of attachment. You may have to get creative and develop a frame to which you could mechanically attach the cedar. Just my opinion.
Likes: Casagf66
Mar 26, 2011
3,684
Corsair F-24 MK I Deale, MD
You might do very well with something like 3M Dual Lock (something like Velcro, but used to hold panels on machines and such). The adhesive has serious bite, and the lining would be easy to replace (cedar only last so many years). The adhesive will probably hold better if you varnish spots on the wood.
Certainly better than carpet in a closet!
Likes: Casagf66
Nov 12, 2014
90
I really like the idea of being able to replace the cedar after a few years, that dual lock sounds like a bright idea. Liquid nail is out the window
Oct 24, 2010
2,405
Hunter 30 Everett, WA
3M5200:banghead::deadhorse:
All kidding aside I think it's a great idea providing you can get it to stay in place as you want it. And I don't think it needs to be thick to be effective.
Ken
Likes: Parsons
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
Hunter made the h40.5 with cedar lining standard.
The new Catalina "5" series also have cedar-lined hanging lockers standard. As previously noted, they do tend to lose their good smell after a while (my boat is a 2012, and you can't smell the cedar aroma at all).
Jan 7, 2015
77
Menger 19 Catboat Annapolis, MD
When I lived aboard my 46' cutter back in the '80s, I lined my hanging lockers with aromatic cedar. You can get "kits" of cedar strips at home improvement stores intended for closet lining.
I epoxied flexible wood strips vertically to the hull, and then screwed the cedar slats to those. Worked great.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Consider sheet linoleum. They now have several really beautiful wood plank patterns, it has a cushioned backing, is easy to clean, easy to cut, will conform to the shape of the hull or locker, and can be applied using a waterproof adhesive. Then add:
Beneteau 323 Annapolis MD
[QUOTE... they do tend to lose their good smell after a while (my boat is a 2012, and you can't smell the cedar aroma at all).[/QUOTE]
I use a fine sandpaper on the cedar to open new "pores" and expose the natural oils. Probably the same oil as in the bottle n post 15.
Likes: Casagf66
DougM
Jul 24, 2005
2,242
Put some closed cell foam insulation along the hull side, then buy some aromatic cedar blocks from someplace like Bet Bath and Beyond and toss them in the locker. Easy to take out and scuff up with sandpaper if they lose their aroma. Just a thought.
Jan 7, 2015
77
But real cedar lining is SO much more elegant (cedar blocks and cedar oil spray...GAK!)
Guess that's why I choose to live in a house with natural cedar siding... I'm sure you guys would choose brown vinyl. ;)
Aug 16, 2009
1,000
I was just kidding about the cedar spray. I was not, however, kidding about the sheet vinyl as I prefer the feel of a cushioned surface on the V-berth, and much prefer sailing to periodically re-sealing or replacing interior surfaces. Brown vinyl? The ultimate in appearance and durability is teak, not cedar. I assume your galley and head countertops are nothing less than polished burl walnut slabs? Where the axes of beauty, practicality and functionality cross is a matter of individual preference and budget.
Jan 7, 2015
77
The OP was talking about the inside of a hanging locker, not the V-berth. My bare cedar lining looked (and smelled) just as good on the day I sold the boat 30 years after I installed it -- with zero maintenance.
My countertops are plain ol' Formica, but at least they have nice varnished ash trim.
I concur that aesthetics are a personal choice, but this old salt could never sail a Clorox bottle.
