N
Neil King
I recently purchased a '94 Hunter 26 that has CDI roller furling jib. The turnbuckle that adjusts it is located under the roller drum, which slides up the flat luff piece holding the jib. The turnbuckle is a solid tubular piece threaded at both ends with a small hole drilled through the middle. There aren't any pins, nuts or clips any where on the turnbuckle. Can it un-screw when the roller is operated to furl? Should there be lock nuts installed at either end of the turnbuckle? (This is probably Question #1 of about 1.9 million more to come).
