CDI Roller Furler
Nov 22, 2017
14
catalina capri 22 1222 delaware river
For a Catalina Capri 22 jib. After several sails, the furler stops winding up completely and some of the jib remains unfurled. Somehow the original number of furling line wraps around the drum diminishes. What may be causing this problem? And how can it be fixed? Thank You.
Beneteau 323 Annapolis MD
Dependng on wind strength, the sail is wrapping up tighter or looser. One of the times the sail does not wrap all the way, take the furling drum line forward and wrap it a few more times around the drum until the jib rolls all the way up. Add a couple more turns if you have enough drum line..
Jan 21, 2009
260
Catalina 30 Lake Perry, KS
OK the fix is simple. Remove both jib sheets from the cars and wrap them around the sail /furler 3-4 times and run them back thru the appropriate jib cars.
