Furlers and backstay adjusters
One very important concept behind furlers is the impact that a loosened backstay adjuster has upon the integrity of the foil or extrusion (the part that goes around the forestay).This foil or extrusion on just about all furlers, with the notable exception of CDI and a small boat Harken unit not readily available any longer, are pieced together onto a forestay. This leaves joints and cracks that may open when the forestay is loosened when the backstay adjuster is loosened. The CDI foil or extrusion is a single piece and thereby bends easily with a loosened forestay.Now if one does not have a backstay adjuster, this is a mute point. However, adjusting luff tension on a jib or genoa is an important sail control even for a furling jib or genoa. As the luff of a furling jib is seated into a sail groove in the extrusion, it is difficult to loosen the luff tension by merely loosening the jib halyard. When the jib or genoa is hanked onto the forestay, loosening the luff with halyard is quite easy.Another fashion to adjust the luff on a jib is through a backstay adjuster. While a backstay adjuster normally is considered a mainsail control, loosening it does loosen the forestay and in turn loosens or powers up the luff on the headsail. Hence, with a furler, a backstay adjuster is important for adjusting the headsail luff.So, if you have a backstay adjuster and wish to use it with a furler, the CDI furler with its single piece foil does have an advantage over a foil that is pieced together.Outside of that, the CDI internal halyard does make the initial hoisting of the jib at the start of the season problematic in that with the exception of the larger units, their fashion to tie down the halyard is poor. This should be modified by attaching a small cleat as on the larger units.The CDI ball bearing option is usually required on boats larger than about twenty-two to twenty-five feet. It is not necessary on a FF2 on a smaller boat.If you are intending to have a yard install your furler, the CDI unit, while less expensive than others, is more labor intensive initially to set up than another unit that has its foil in sections. In this respect, the CDI is probably better as an owner installed item, while other brands would be better for a yard to install.I have a CDI FF2 that I installed onto my C-22. I made several modifications to make it work better. I also have a backstay adjuster. The CDI is a robust, simple unit that serves me well, yet I dread the difficulty of hoisting the jib every spring.Bottom line is that the CDI is an excellent unit but in my opinion somewhat inferior to other brands. However, I do have a backstay adjuster and have great comfort knowing that there are no connections to worry about when I power things up loosening the backstay adjuster.
