CDI furler 2
May 9, 2010
131
Hunter 23 WIll be at a Navy base
I have a CDI 2 furler. I need to know what kind of rope and size that should run from the sail to the cockpit? Any help would be appreciated. I have been away for awhile, so I am not up on the latest.
Thanks,
Dec 2, 1999
15,184
Contact the SBO store. They have what you need at the right price and correct measurments.
-na -NA Anywhere USA
the furling line used was either 3/16 or 1/4. The actual length will be determined when the sail if furled with about 4 extra turns to where it will be tied off in the cockpit as the length will vary. If you have the old one, then measure and add or detract based on too much or too little or just right.
Mar 27, 2010
84
Hunter 240 Branched Oak Lake, NE
I have CDI 2 on my 240 and just replaced the furling line. the original line from PO was 3/16", but I went with 1/4" after recommendation from Crazy Dave (thank you, Dave). Much easier to operate. I wouldn't go any bigger, though, as you're liable to run out of room in the drum. I ordered 30 feet of sta-set double braid, which is just right for my 240 with standard 110% genoa (measured drum to cockpit and added 15 feet).
jblersch;
thank you sir for helping out on this one. It is fellows like you which I am grateful for helping others. Take care and God bless.
