After our very successful mast raising event today we (naturally) had to encounter new and inventive problems with our CDI Flexible Furler.
We raised the jib sail without a problem, but then I went to do the same thing I did last year, connecting the rabbit (may not be the technical term, but the triangular piece of plastic on the bow side of the furler track used to haul the jib up) to one of the (for lack of a better term) shackles on the furler drum cover, and then the foot of the jib to the "shackle" as well:
Well, imagine my surprise when I found the "bolt" or "pin" that those "shackles" are on had actually pulled through the Bakelite-like cover. One of the "shackles" was missing and the whole thing was a mess.
So we did what any good sailors anywhere would do. We improvised:
Unfortunately, the improvisation isn't working, and we may also have a related, or separate (hard to tell), issue with the drum of the furler in that trying to pull the halyard out to roll up the jib is resulting in some amazing amount of force to be needed to accomplish anything at all.
This is a jib furler which worked just fine last year.
We're at a bit of a loss what to do here. I don't know if there is a quick fix we can use local off-the-shelf parts for, or if I'm going to have to order something expensive and pay to get it shipped here fast in order to start our sailing season this weekend.
Any help you folks can provide would be gratefully accepted.
