Yikes! Not 5200!!
While I agree in principle with LaDonna that 5200 stops just about anything, it's NOT the best bedding compound for hatch plex or glass. For example, should the plex or glass ever BREAK, then you will have a helluva time replacing it.When I bought my 78h30, I replaced the plex in both my hatches with tempered, tinted 1/4" safety glass. Major manufacturers to it, so why wouldn't it work for me? Anyway, I used 3M's marine-grade silicone seal. That was 3 years ago and they are still not leaking and the silicone is in good shape having weathered 3, going on 4, Texas summers without any perceptible UV damage. And, with silicone seal, the stuff lets you know when it is time to re-goop it!!I also chose glass because glass is static and stable and doesn't "move" like plastic plus the added weight of the glass helps secure the hatches. So, whatever material you use in your hatches, and while 5200 is certainly the preferred adhesive/sealant in some applications, my preference is 3M's silicone for this job.Good luck.
