Caulk/sealant for shower enclosure with teak trim
Feb 16, 2021
438
Hunter Legend 35.5 Bellingham
I’m not sure what was used before, but the old caulk is failing and needs to be redone. Any recommendations? I know a lot of folks hate silicone sealant, but would it be appropriate here? I want longevity and don’t want the caulk to yellow.
Also, prep the wood and walls with acetone?
Use a good quality bath and tub caulk. Meets all the necessary criteria and is not exposed to UV, so "marine" caulk is not necessary.
From another thread you were looking for these:
Likes: skunther
Feb 16, 2021
438
Thanks, those are just what I need. Could only find 1.5” on go2marine.
some of the existing caulk has yellowed (apparently the PO had added some caulk on some seams). I assume it’s leaching color from the teak. Is that more of an issue with some caulks than others?
