My C27 has the sliding gooseneck shackled at the bottom to a loop screwed into the mast track just underneath.
When I purchased, I noticed the sail did not go all the way to the top. IF the sail was cut correctly, this means I can adjust the sail higher or lower, which is part of the discussion in this thread.
I am assuming I would need to move the screwed loop further down the mast and put in some different lengths of line, different length shackles (not sure what lengths are available), or a block and tackle with a cleat?
Am I on the right track? (apologies for the pun)
What have others done to secure their goosenecks when underway?
