catalina capri lift off
  • Thread starter bill dieffenbach
  • Start date
bill dieffenbach
Hi guys, I have recently purchased a capri 18 and would like to know what is the best way to sand and paint the bottom if the boat is on a trailer with bunk rollers. The bottom needs a good sanding as the paint is worn off wearever the rollers are in contact. I am thinking about removing a roller assembly and doing one area at a time. The winged keel is taking the weight and it sits on a padded beam that has a built in jacking assembly. The trailer is a galvanized load rite and is in great shape, the only things rusted are the attaching hardware like u bolts and nuts. I have jacked up the axil and put supports under it for the winter to get the tires off the ground. If I were to get blocks under the stern and lowered the tires back to the ground the weight should be off the rear roller assemblies. Any sugestions? Bill
Jun 5, 2004
97
- - Greenwich, CT
Painting bottom on a trailer
I have a Catalina 22 with a Load Rite trailer and thirty-two rollers. I put a power boat stand under the transom to steady the boat on the trailer. Then I use another power boat stand near the rollers, a section of eight, that I remove so I may reach the bottom more easily. So, four sections of rollers I remove, one at a time, to properly sand and paint the bottom. Ah, yes, the pleasures of sailing. For a Capri 18, the process should be much simpler, not to mention you have a heck of a lot less boat dangling above you. On the other hand, I know someone who flipped his C-22 over to work on the bottom, While that is a bit extreme for a C-22, I think it would be a great solution for a Capri 18.
