Catalina 310 Cabin Top
Catalina 310 77 Atlantic Highlands NJ NJ
I need to drill a small hole through the cabin top to run a wire. It will be just aft of the traveller on the port side.
My question, is the cabin top cored or solid glass. This will determine how I proceed. Thank you
leo310
Dec 15, 2006
650
Catalina 310 44 Campbell River BC
what you may want to do is drill a larger hole then fill it with epoxy then drill the hole size you want. This will seal the edges of the hole.
Joe
Jun 1, 2004
8,261
I can't imagine any Catalina sailboat that doesn't have a cored deck as a cabin top. Usually marine plywood. If it's critical to know before hand, a test hole is your best option. Easy to patch too.
