Mark Jones
While in forward and approx. 75% throttle engaged, the engine will occasionally begin to accelerate as if the load was removed from it. I reduce throttle to idle, pull shift to neutral and then re engage it in forward and slowly add throttle. Sometimes it repeats and sometimes not. I have adjusted the clutch mechanism and it appeared to be a positive engagement of the calipers over the shaft sholder. Any ideas?
