W
W.I.Mackenzie
I have a 30' Catalina with a 5411 Universal diesel engine. All of the information that I have found state that this engine should produce appx 3000 rpms at full throttle. I can only get 2100 rpms whether I'm in forward or NEUTRAL! This could be a tach problem, but why the same rpm regardless whether I'm in forward or neutral? The forward top speed at full throttle is 4.8-5.1 knots(that is with no head wind or seas).Does anyone know what the top speed this unit should have? Is the 4-5 knots at full throttle right or should it represent appx 80% (cruising speed)? Is there a governor that is out of sorts? I cleaned the prop and couldn't find any info on the size and pitch. It is a 2 blade prop which may be the original from the mfg. The engine cranks and runs well and the bottom is clean! Help!!!!
