rccaptain
I had a sight fuel leak and also was clogging primary filter alto after a long trip. removed the tank to clean it out then filled it up to leak test it and found three pin holes that are from bad ground. My question is has any one tryed to weld these aluminum tanks to repair or is replaceing the only way??? Any info is appreciated.
