Factory Install
Here's a rather poor picture of the factory installation on my previous boat - a 1986 C27.The halyard exits the mast on the starboard side, is led to a turning block and then straight aft to a single rope clutch. (on the port side, the arrangement is copied, only two jib halyards are led back to a double clutch).The second line you (might be able to see at the turning block is the main sheet. It runs back, with no clutch.The winch (a lewmar Self Tailing 16 - I think) was through mounted in the coach house roof, and shared duty for both the halyard and (once the clutch was secured) for the main halyard. It has a blue cover in this picture. There is also a mess of mainsheet stowed up there in this picture.Sorry about the poor quality picture.Tim BroganApril IV C350 #68 (was Inamorata C27 #6111)Seattle
