Standing rigging
Generally speaking there isn't anything "wrong" with their standing rigging. What you may be seeing are older boats whose rigging *should* be changed every 10 years or so, especially in the Bay area. Now older C27s do have a reputation for their eye-bolt chainplates failing after many years of service. I, unfortunately, experienced that first hand when a shroud popped while sailing. Luckily, tragedy was averted but it did teach me a lesson: don't put off today something that could take your mast down! If you look at older C27s, check out the lowers (well, actually check all of them!) to see if they have the U-bolt upgrade. No big deal if not, the kit is all of $70 from Catalina Direct (although delivery time can try your patience). Also check the upper chainplates which are attached to the bulkheads. What you're actually checking will be the bulkheads cuz if there have been any leaks, the bulkheads can deteriorate, making the chainplates compress into the wood. That would definitley be a costlier repair. I'd probably walk away from that, considering how many boats are for sale down there.So, to make a long story even longer, don't worry about boats that have had their rigging changed. That's a good thing! Doesn't mean the old rigging was inherently bad, just means the owner was really good on upkeep.LaDonna
