Catalina 250 leaks
Oct 6, 2016
2
Catalina 250 Columbia, SC
There seems to be a leak near the stern of my Catalina 250 which, with heavy rains, rally soaks the sleeping area. I can't see any visible openings. Any ideas ? Thanks
Sep 8, 2014
2,551
You have a trailer? This can be done dock-side too, but easier at home. The way to test is to get inside and watch while someone uses a pressure washer on deck to wash down, simulating heavy rain. There are numerous possible sources; deck hardware, cockpit locker seals, windows, etc.
Jan 6, 2010
1,519
John,
To get the best responses , us guys, need greater detail.
Thorough Investigation on your side first, details & some pics may
be able to give you sound ideas for fixes pal.............
This is a great forum, why knot take advantage of it?
CR
TEM58
Apr 4, 2013
25
Catalina 350 35 Belton, TX
There are several possible culprits. The very first thing I would check is inside the coaming boxes. The seams inside are notorious for leaking. You can seal them easily with the caulk of your choice. If that doesn't stop the water then it's on to more detailed checks as mentioned above.
Oct 6, 2016
2
John,
CR
Will do when Hurricane Matthew passes. Thanks
