Catalina 25 Motor Mount
Mac
Jun 7, 2006
436
MacGregor 25 KEUKA lake NY
The top two bolts on the motor mount have loosened, the bottom two seem to be tight, at least the mounting isn't pulling away from the hull but that might just be because of gravity. Anyway, does anyone know how a person gets to the nuts in order to hold them while tightening the bolts?? The C-25 seems to present some real problems for rebedding hardware. Any guidance or suggestions will be greatly appreciated.
jm
nut tightening
I'm not sure if mine are original, but there are four carriage bolts that attach my motor mount to the transom - access to the lock nuts is from the rear berth, just above the shelf. I have added four backing plates (3" square washers") to give it more support.
