A
Andrew P Thibaudeau
I have a 1982 Catalina 25 that has a large bulge on the keel caused by rust. The bulge is open at the top and is 6 inches across by 8 inches down. I alsofound that there are small areas (nickel size) on that side of the keel that are soft and when I press on them rust colored water comes out. Could you recommendthe best way to go about fixing this problem. I really want to do it right so I don't run into the problem again. Any help would be greatly appreciated.Thanks
