Catalina 22 Masthead Help
1
- - Port Orchard, WA
I will be stepping the mast to install the VHF antenna, Windex, and anchor light. I purchased from CD the VHF Antenna Kit the Windex the rides on the antenna and a neww anchor light with mounting post. With the windex mounted on the antenna it seems to me like it will hit the anchor light even with the antenna mounted as high as possible. Any suggestions?
Ray
Mar 10, 2006
94
Hunter 26 Kettle Falls Wa.
Look in the CD catalog at page 4.29.3
The anchor light mounts on a post. The VHF antenna mounts forward of that. You will need to make a "L" bracket and rivett it to the side of the mast. You drill out a hole large enough to fit the antenna. Be sure to rivett below the installed depth of the mast cap when the cap is installed. The windex mounts on the aft end of the mast cap and is mounted on a SS bar that is about 5/8" wide, 3/32 thick and about 7" long with the windex at the rearmost end. All my goods are from CD and this mounting set-up works nicely. A spinnaker halyard also fits in perfectly. Ray
