Bob Nesbit
I'm trying to put the leel (full keel) back on a Cataline 22. All 6 bolts were broken off. All bolts ere iron. I have removed all bolts (studs). I now need to put it back together. What is the proceedure? Should I use studs or bolts? Stainless or not?What prep should be done?What goes between the keel and the hull? Is this what seals it all?Do I use something different around the bolts/studs? Is this what seals it all?Should I grind down the bottom of tthe hull to take out all uneven surface? Does the "stuff" that I use for the keel seal squeeze out to also be ground off to make the hull smooth and beautiful without a seem or will there be a seem (so make it a pretty seem)?Regards,Bob Nesbit
