Catalina 22 flat area
Peter Ferguson
I am Thinking of purchasing a Catalina 22 but it seems to have two main problems that might or might not be related. Firstly the trailor is not intended for the vessel and although there are some rollers for and aft I think some weight is on the centre keel. Secondly there is a flat spot aft of the centre keel as if the boat has been rested on ar ailway sleeper which has dented the fibre glass by 1inch Max from beam to beam. Can anyone suggest the severity of these observations. The rest of the boat seems ok new engine so I am a little tempted. Please put me off before I buy my first boat!! Many thanks Peter
david
hmmm
Dear Peter, The C-22 is a terrific boat! I am not sure about your particular dilemma, but it might be money well spent to have a marine surveyor go over your potential vessel. A major flaw could be hugely costly, not to mention any structural seaworthy-type problems that need to be identified. good luck, david
Brad Williams
Hmmm, agreed
I'd have someone look at it....depending on how much you are talking about spending for the boat. Regarding the trailer.....I don't remember the specs, but a certain amount of weight is supposed to be supported by the keel while sitting on the trailer....it doens't necessarily sound like there's anything wrong there. Best of luck....let us know what happens. Brad
Peter Ferguson
Thanks
Chaps, thanks for your swift reply! Message understood, that in this instance a Marine survey would be a good idea. Cheers Peter
Brad
No Boat Weight on Swing Keel!
Peter, If you are looking at a swing keel C-22, a properly rigged trailer will allow the weight of the boat to be carried by the rollers and/or bunk boards. The keel should not be supporting any boat weight. However, if you have a fixed keel C-22, I believe the keel should be able to support some weight. Most of the boat's weight should rest on the rollers and/or bunk boards. This will alleviate stress in the keel area and possible structural damage while trailering. Best wishes and happy sailing! Brad s/v Worthless Crew 1972 C-22 SK
Scott K
No weight on swing keel...ibid.
No weight on the swing keel! I just dropped the keel from my boat to conduct some long term maintenance. If any weight was designed to be on the keel...well, you can imagine what would have happened. Indeed, when pulling the boat from the water, you'll have the keel fully retracted. Only later will you lower the keel until it is supported (vice supporting) on the "V" near the trailer axle. The only reason for the keel to rest on that "V" is to take tension and wear off the keel winch. The only thing holding a swing keel to the boat is a pin and a bit of cable. Definitely not intended to take the weight of the boat. Scott
