C
Chet
The two drains in the cockpit of my 1974 Catalina are clogged so that it takes an hour for even a small amount of water to drain. It appears to be stopped up below the shut off valve which is back of the battery compartment in the cabin. Where does this drain exit from the hull? What is the best way to unclog it? If anyone knows a solution, please advise. Thanks
