Catalina 22 bilge care
Aug 21, 2023
2
Catalina Catalina 22 8023 Canyon Lake
Just bought a 1978 Catalina 22 that I can't figure out how to drain the bilge. There are 2 cockpit drains and the sink drain the go to a drain that feeds into the swing keel pocket. I can't find any other opening, does anyone know of one.
Thanks guys
Oct 13, 2020
173
catalina C-22 4980 channel islands CA
On my 1974 C-22 there is no drain for the bilge. I have had no need for one since I do not get water in the bilge. The bilge should be dry after sailing. If your bilge is wet after sailing you may need to find the leak.
Dano
Likes: ggrizzard
JBP-PA
Apr 29, 2022
620
Jeanneau Tonic 23 Erie, PA
Most larger boats do not have bilge drains. Use a bilge pump for large amounts (which you should not have on a Catalina 22). Use a scoop and sponge for small amounts.
The Bilge is usually below the water line. You would not want a "drain" there.:yikes:
A small bilge pump is easy to instal but you will still need a sponge to get the last little bit out.
Are you getting water after a rain or after sailing?
